R4R&R wrote:echo wrote:NASA/military doesnt want flux on the solder connections. They have VERY high cleanliness standards for circuit boards. Why? Corrosion over decades of use. So they make us clean everything in a high pressure soponifier solution in a special machine. The high pressure solution can get into sealed parts and ruin them! And the thing is, its only old fashioned acid fluxes that corrode things. Rosin fluxes if reasonably cleaned wont hurt a thing. Ah but it gets deeper! Acid fluxes actually give a better solder joint than rosin fluxes! Acid flux is easily washed away with low pressure soap and water! So theres NO CHANCE of it getting into sealed parts! I know this because I work on a bench every day for 30 years soldering things. But...the ding dong people who sit behind a desk all their lives and write the specs dont have a clue. They make us use rosin flux (which wont hurt a thing) make us wash the boards in a high pressure cleaning machine (which can ruin the parts) which produces an inferior (but adequate) solder joint!
That's hilarious! Typical suits thinking they're doing things more efficiently!
Its even more unbelieveable than that. I think these specs are more about politics that actual production reality. (if something fails something (or someone) must be made to blame)
